I dont think many people on this forum ant really willing to
shockwaves
Mobile into a flat? what do i need to know! prove me wrong! im sure there are other CB forums out there!
ah useing esp have decifered that you whantto put a mobile cb into a flat you need a power supply that will give you 13.8 volts 3 amps minimum and a dv 27 antenna with a ground plane and you should be sorted the parts can be got from our sponser and if you talk to colin he will sort you out todays password is (haddock)
shockwaves
hello!! yes thanks for that! I knew some one must get back to me! i was going to use a big leasure battery for the time being for the radio as i have a car battery charger if it ever got flat! If i was to mount the mag mount on the floor on a sheet of steel behind the tv you think that would work? i live in a built up area and ther is a few people on the radio! i normaly use the radio in the off roaders sho she gets beaten about! i use the burner and im well impressed on the range ive had 40miles or so!! Newbury to Gilford reading at 5 pounds! on a budget rig! my radio is a moonracker! like i said its normaly used in the off roaders! and i have seen many radios go swimming!
shockwaves
Hello thanks for getting back to me! coax!! whats this not heard of that before!! it sounds good stuff!!! i will google it now!!
shockwaves
hello!! yes i now what coax is! right bear with me how do i connect it to the bottom of the areal? im guessing ignore the mag mount! the becasue the coax cable has a solid wire running thro the middle and a woven on the out side do i attatch the to, to the areal and the other end on the coax do i connect up to make a loop? and thats ya ground plain? also what lengh on coax would work best? 3meters??
thanks! if anyone could help!!
shockwaves
hello hello!! I think I have ya!! the dv mount I take it is the bit on the end of the aerial the bit with threads on it and that bit slots into the biscuit tin and the coax on the end of the tin hu!! hu!! hu!!
the dv 27 is a antenna not a mount i think you have your wires crossed
shockwaves
yes i have got ya! i will have a look for the dv 27 now!!! thanks guys for ya help!!
