Hi All, My set has worked perfectly for the last 2 yrs with a good range, however the other day I got in the truck & found that the ariel was missing, I replaced it with a new one & since then have only 4-5 bars signal strength on transmit( most of the time 0 bars and can't transmit) and a weak reception. I have swopped mikes for a known good one & fitted my old ariel but it's still the same, I have moved the ariel connector around while pressing the transmit button & that makes no difference either, anyone got an idea of my problem please?
P.S. I can be heard, but only when another radio is very closeby.
Cheers, Hayabusaman.
Weak transmit signal
yes as stampman says swr is a must
sounds like you need to swr that antenna
- Nugsport
- CB Handle: Nugsport/Steve Alli-monster
Did you by any chance key the mic on the radio without the antenna conected, before you noticed the antenna was missing.?
Steve
DX The World
"Check Your Band Plan"
Homebase - Magnum S-9 Nitro Export > Sirio 827
Mobile - Midland Alan 78 Plus Multi > Sirio Megwatt 4000
26 PW 353
good point could have blown the set
could try a dummy load
- Nugsport
Just what i was thinking matey the Output Transsistor could have gone. hopefully not for his sake. but you never know!
Steve
DX The World
26 PW 353
if you followd the instructions on the swr meter then it looks like the set needs tender loveing care with a five pound hammer by a good rig doctor keep yor fingers crossed and it might only be a 2 pound hammer
