hi everyone, im new to cbs and to this site and could really do with some help!
I've got myself a maycom em 27 cb with a 5ft stinger style antenna and a stainless hatch mount which I have fixed onto the back door of my land rover discovery!
when i first got the cb i switched it on with no antenna connected and was greeted by lots of squelch, now when i turn on the cb after fitting the antenna i get no sound at all!!
I really dont know what ive done wrong so any help would be greatly appreciated!!!
maycom em27 help!
this is usual because of the background noise turn the squelch up full and the busy light will go off dont know the point of the light except it looks good could be for deaf operators possably ?????
Hello again.
Thanks for all your advice before CB was working fine until recently.
I have an intermittent fault with signal being received. Sometimes the signal bar shows 3 or 4 bars but then it just dissappears, like as if I have disconnected the arial.
I've tried my arial with another CB and it works ok, so my guess is that the fault lies in the cb itself.
Anyone got any idea on how I can fix this?
Hey stampman,
from what u've said it strikes me that you think it will be working and the cb is trying to play tricks on me?
Sorry if I'm being daft
PS. the one thing I didnt try when I was swapping CB's and antennas was to check if I could hear the other person or if they could hear me!!!
It seems that there's something wrong with the EM-27's / RadioShack's design. I say that only because my RS Version blew up and my MAycom version had the same problem.
Make sure the RF gain is right up and the squelch is set just a degree over when you start to get the static sound.
As for the 20ft range How is the radio antenna mounted? If you have coax going up around the door or through the window to the roof of a car say, it could have made a break or short in the coax, which will mean its replacement time.
HARRIER - CBX ---quality CB built on the famous Cyberrnet 134AOX board.
'Breaker One-Nine, what's your 20? I Hammer'd Down on the A3
I eyeballed a Kojak with a Kodak so I pulled in behind a Suicide Jockey.'
