Cybernet beta 3000 cb
andyd99
- CB Handle: andyd99
Does anyone know if the audio can be turned inside the above rig? Works great but everyone i speak to says the audio is really low. Got my swr really low to about 1.5, can pick up loads of people on loads of channels, and transmit ok, but just wondering if it can be done, does anyone know if its a big job??
The Cybernet Beta 3000 has no Mic Gain, The only way I see you being able to get a higher audio level is to use a power mic. The Beta 3000 I had a few years ago came with a [Non original] power mic- No bad reports from it unless I turned the mics power down. I also see a lot on ******* with power mics so maybe the audio is like this on all the Beta 3000's?
HARRIER - CBX ---quality CB built on the famous Cyberrnet 134AOX board.
'Breaker One-Nine, what's your 20? I Hammer'd Down on the A3
I eyeballed a Kojak with a Kodak so I pulled in behind a Suicide Jockey.'
Had a look in my old scrible pad and i have the beta 3000 as having a mike gain horseshoe trim pot . it was a long time ago when i worked on one so cant be certain it is correct.
This board , PTBM134AOX is also used in -
Harrier CBHQ / CBX
Binatone 5 star
Binatone Speedway
Fidelity 2000
Transcom GBX4000
York JCP 863
Harrier CBHQ / CBX
Binatone 5 star
Binatone Speedway
Fidelity 2000
Transcom GBX4000
York JCP 863
