I have a Chevrolet astro van, which has a fibreglass roof, therefor no good for a mag mount. I was told that i needed a No ground aerial.
I bought a SIRIO no ground aerial, which i have mounted on the spare wheel carrier on the back door. The cable that came with the aerial was not long enough, so rather than join it, i bought a four metre cable with the connectors already on.
I have the cable going between the hinges on the back door, rather than drilling holes, the door closes so i hope this does not damage the cable.
I have been told that no ground aerials, do not need to be earthed, is this correct ?
I have got a Midland alan 48 excel multi, which i power from a cigar lighter socket. I have connected the aerial to the back of the radio, i turned it on and all i am getting is noise, i have tried all channels but am getting nothing. When i press the mic button, the signal pointer goes over just over half way, this seems excessive to me.
Also it says that this rig comes set to EC frequencies , how do i set it to UK frequencies ? Simple as possible please as i only have one arm.
Sorry this is long, i hope i have explained everything, as not very technically minded.
Any help please, would be much appreciated. thank you
NOT SURE WHAT IS WRONG
I have no experience with the particular antenna you have, but I do know that some no-groundplane antennas rely on a specific length of coax in order to work - best check with the supplier or search the internet to see if this is correct for your Sirio.
Even with so-called pre-tuned antennas it's vital you use a SWR meter to check the installation
There's a review of the Midland Excel 48 on the T1 website http://www.transmission1.co.uk/index.ph ... cle&sid=48
It contains the following info...
"I have seen in a lot of adverts for this radio that if you select the "UK SETTING" you get access to both the UK 40 and the CEPT 40. That's 80 channels in total. This is not true (at least on my one). You have to switch the radio off. Hold down the N.K. (ESP II) button and switch it back on to go into Country setting select mode. You can then switch between UK or EC settings with the channel selector dial. Not a major deal, but something I haven't seen mentioned in any adverts. Also, you can only scan (or DW: Dual Watch) which ever of the 40 channels you are in. You can't, for instance: scan both UK 19 and CEPT 25 (both bands calling channels). That would have been a very useful feature."
I've no experience of the radio myself.
Hope this helps a bit.
has the astra van a gutter on it if so use a guttermount or you can get a boot mount which will fit on the rear door and fit a proper antenna as the no ground antenna give you a perfect swr but do not work well for distance
you will have to get help to change it to uk as it is holding a couple of buttons in while turning the set on as per the book of distructions
Thank you all very much for your help and advice. Unfortunately my astro does not have a gutter. could you please tell me
how the boot mounts attach, will it fit flush on the rear door, and will i have to drill through the door?
Many thanks
Many thanks
- killer cam
- - - -> CB God <- - -
- CB Handle: killer cam
i dont sorry but if you give thunderpole a ring on 01604 402403 if sure andy would go thourgh in detail on the fone with you he did it with me when my rig played up but you might need some help as you have one arm sorry hear that mate but lets hope you get on the airways
the boot mount comes in various types but all mount on the lip of the door or boot so if you talk to andy or colin then they will be able to sort you out and its better than fumbling in the dark all though on second thoughts not as mutch fun
- killer cam
GOOD OLD ANDY must say hes very good a his job lol iv just installed my mini tornado stinger with a mag mount its great
