Major M360 - Help!
disgwylfa
CB Handle: 186-TM-555
Hi
I've recently come into the possession of an old Major M360 that has apparently spent the last twenty years in a loft. Naturally there is no user manual with the beast but most of the controls are blindingly obvious. EXCEPT the two switches for the Bands.
Instead of a nice simple knob with Lo/Mid/Hi/etc. on it (that'd be far too simple) the M360 has two switches: the left one is marked HI and LO and the right one is marked "HI BAND" and "LO BAND". Can anyone please enlighten me as to which combination is appropriate to which bands? Or, better still, does anyone have a copy of the user manual for this rig?
Thanks (hopefully) in advance
Steve
Offplanet
I've got one of these coming my way soon so hopefully it's not too difficult :shock:
All I could find on the internet is the following:
Major M360 120 Ch AM/SSB/FM
120 Channels in 3 'shifts' - Mid, High, High-High.
Has DX/Local switchable attenuator and switchable NB+ANL. Specifications claim 10W AM/FM 12Wpep SSB.
Lovely low noise high sensitivity receiver.
There was also an M588 which was an 80 Ch version.
The above is a result, as I thought it was only an 80 channel rig :D
I've got a frequency counter, so I should be able to help soon (that is if the rig I'm getting works)
killer cam
CB Handle: killer cam
stampman will know probs
not seen a major for years you realy need a freq counter on it because odds are it will have been moded so a counter will tel you exactly what is wareand if it is lined up for uk fm
disgwylfa
Hmmm,
Methinks I might just have to use this as an excuse cough-out for a frequency counter as Stampman says - time to start surfing for a reasonable price on one. There's no signs that the M360 has been modded but I guess the frequency counter would finally resolve it once and for all. In the meantime if you get a result when your Major arrives Offplanet, I'd appreciate any help.
Thirty years working with computers tells me that two switches, with up/down on both, gives four possible combinations (2 bit binary) so how the heck it gets to three bands (Mid/High/Highhigh) is beyond me. If it had FOUR bands and 160 channels (Low/Mid/High/Highhigh) it'd make sense. I've found a place in the USA that claims to have a user manual for sale, but their $27 (about £20) price sounds like a way towards buying the frquency counter anyway.
Of course, this all assumes the beast still works after its years hiding amongst the cobwebs 8-[ My old 2A PSU didn't have enough kick for me to test the rig so I've had to get one with a tad more amperage . . . .
Offplanet
I'm hoping to have the rig on Saturday - I'm not a lucky person, so I fully expect it to be a joey :(
If by some miracle it is Ok, then I'll post the frequencies the same day.
$27 for a user manual is daylight robbery - I doubt there's 4 pages to it :shock:
killer cam
:shock: :shock:
disgwylfa
I've cracked it - with a little help from a Frequency Counter as per Stampman's suggestion.
The M360 has been modded by the inclusion of Muppets band using the NB/ANL switch. If the NB/ANL switch is up and the rig is set for HIGH band , it goes onto UK CB27/81 "Muppets".
Otherwise, with switch to OFF, the rig has MID / HIGH / HIGH HIGH as expected - the freqs are fractionally little off spec but the clarifier has (apparently) been unlocked and the TX can be tweaked with that.
If anyone else wants to know the settings for the three bands, the image below will (hopefully) show the switch positions
(the ones marked "XX" are non-bands, half-way between normal bands, caused by the Muppets mod):
. . . . . . . Image
thanks you cant beat the right equipment for the job saves a lot of what ifs
killer cam
yep thats true
Offplanet
Steve - nice pictures of the rig switches and a good explanation.
Mine arrived, and despite a very tatty look, works very well indeed (good RX and TX) :D
It has been modified, but not to the extent that yours has - the NB/ANL switch just works as a frequency shift and, when on the right channels for UK 40, puts them spot-on.
The mid, high and high-high are exactly the same as yours, with UK channel 1 being on high channel 56 and UK channel 40 being on high-high 53 (with the NB/ANL switch on)
I'm going to give it a good clean this week, inside and out, and treat the case to a matt black respray - should be a tidy rig then.
Cheers.
disgwylfa
Hi Offplanet,
Glad to hear your M360 arrived and wasn't "the Joey" you feared :) And it is strange that you should mention a "tatty look" and "a matt black respray" as I have a can Plasti-kote's Fast Dry Enamel in "Flat Black" right in front of me, waiting for me to take the covers off my rig.
Good luck with it.
killer cam
:D
Offplanet
Sounds like we've picked-up a couple of gems amongst the joeys :D
I'll be doing the clean up and respray this week, with a view to giving it a try out on DX SSB at the weekend - perhaps catch you on 27.555 sometime.
Regards
killer cam
gdgd
