i noticed that swr can go up quite a bit when hooking up a linear amp , so keep an eye in it,, also i bought a kpo 45 amp power supply with amp and volt readout, with a rm kl400 amp i measured a pull of between 10 and 20 amps,
depending what extras i am running from the auxillarys ,
Burner
- killer cam
- - - -> CB God <- - -
- CB Handle: killer cam
it will rise
- killer cam
i would say it will go up to 3 or 5
hotmetal1000
Depends how well the swr was set at low power. The closer to 1:1 at low power it is the less it will rise with more power.
- killer cam
i got mine dead on 1;1
- killer cam
dont u mean to say that to fish
