K40
hotmetal1000 wrote:coax lenght can change swr readings normally only ever so slightly. If the swr is going out big time with differant coax lenghts than I would say the K40 has some other design problem.
BANG ON !!!!! =D> =D>
piper spence
CB Handle: Piper
Hiya, I have noticed with some antennas such as the small indoor antennas like bazookas ect can also have this problem with coax length affecting the SWR. I think its the way thay have been trapped makes them sensative. Just moving them around the room can drastically affect there SWR. I have had the same problems with homemade antennas if I have coiled them a lot.
.......It's Mental being Mental.....("\(¬_¬),,
killer cam
CB Handle: killer cam
Haggis
Is it not possible to put some kind of plug (in the coax) about a foot short of the magmount so that the hole magmount could be unplugged and stowed away???
killer cam
stamp man will know that
yes you can do that make sure you use 2 x pl259 and 1 double ended so239
:D :D :D *King* *King* *King*
Road_Hog
stampman wrote:yes you can do that make sure you use 2 x pl259 and 1 double ended so239*
A PL258 even.
i knew what i ment must have been useing the esp thread again
FISH
Been there done that didnt like it.
26 TANGO MIKE 501
it does take a bit of practice in a dark room after 10 largers
killer cam
lol
its a shame there not that good because there very discreet ..
to a blind man doing 70 on a motorcycle possably
FISH
Its name is still living from the 80s,and people packed them away in the loft instead of getting rid.
26 TANGO MIKE 501
killer cam
yeh they have a name for thyem self
