Signal Meters - Usefull or Not ?
TheJester
CB Handle: The Jester
Newbie CB`er here again with another "Probably Obvious" question...
I have a Team Me4, which as you are probably aware doesnt come with a signal meter...
So my questions are :
1. Are Signal Meters Beneficial And If So, For What Purpose(s)...
2. Can you buy add-on, external signal meters to plug into the back of your cb... ?
As always, comments much appreciated...
HANDLE : The Jester
no not necessary drive you daft and give you an inferiority complex
yes you can
TheJester
Cheers Stampman, on the ball as always, with a straight forward answer....
Got any links to a add-on s-meter (Just out of interest...)
HANDLE : The Jester
not allowed links as per rules search on the net and you will find
hotmetal1000
Signal meter is only a guess meter and honestly what does matter what signal they are doing to you, so long as you can hear em.
disgwylfa
CB Handle: 186-TM-555
Stampman is, as usual, quite right when he says that focussing too much on an S-Meter can ' drive you daft and give you an inferiority complex '. But there are, albeit rare, occasions when they're useful:
It’s not just for responding to the inevitable “can someone give me a rig-check please” which is always difficult if you don’t have an S-Meter, but when DXing it can be helpful if you’re able to see what signal strength is coming in.
There is one occasion when a clear S-Meter is very useful indeed, and that’s if you’re into Very Serious DXing and using a Yagi or Beam antenna – the S-Meter is the simplest way to direct the beam.
As for ‘ search on the net and you will find ’, you must be using a different net to me Stampman ‘cos I’ve looked and only ever found one, in Germany, at about 50 Euro plus postage. I think it’d be easier to find a UK site that sells Rocking-horse Manure. :wink:
had a chat with our sponsers and the price that they would be is asronomicl very high not a cost efficent unit big bucks for little return so not worth it try makeing your own out on a volt meter
