Best CB Radio for Europe Trip?
oldskooldaze
Wilson 1000 drilled through the roof
This looks like a bloody good solution... if it works??
http://cgi.ebay.co.uk/Midland-car-aeria ... 7C294%3A50
- andy@thunderpole.co.uk
- Site Admin
If it works! Yes, exactly!
I cant imagine that would work very well if it worked at all.
IMHO that "CB Car Aerial Matcher" idea is a rapid way to Rig Suicide.
There's no way you'd get an acceptable SWR for Transmitting on that gadget, maybe OK for receive-only but, if you're TXing, it'd only be a matter of time before the CB coughs and dies.
As Stamp mentioned earlier, "way-back-when", a company called Antenna Specialists used to sell a superb "subtle" twig (the Antenna Specialists MS264). It was about 24 inches straight steel semi-whip (just like a car aerial) and it had a take-off for the car-radio so you only had the one aerial on the car. It was tuned (SWRed) thorugh a little built-in antenna matcher. I had one, back in the (illegal) pre-27/81 days and ran a Cobra 146 off it, SWR of 1.2:1 and good contacts. I haven't seen one YEARS but if you see an A.S. MS264 for sale anywhere, that's the one I used to use. In fact, if you see an AS/MS264 just tell me and I'll buy it out of pure nostalgia.
You really don't need to worry about an antenna coming off, even at speed, unless you're talking about a large twig on a small mag mount or something equally ill-matched. A boot, gutter, hatch-type mount will hold damn near anything at any practical speed. And, if you're planning outrageous speed on a Track, just unbolt the twig for the afternoon . . . After all, if you're honking around a track at 170mph it's unlikely that you're going to be calling "one nine for a copy" while you're at it . . . (170 mph? in a Nissan "Z"? What HAVE you done to it?)
Oh, and I just have to totally agree with all the other comments about the glass-mount antennas, they really are the last-resort solution and if you're going down ot that level of performance, you'd almost be better off buying a hand-held and holding it out of the window / sunroof.
- porky.69
- - - -> CB God <- - -
no junk that couldnt pick up a cold lolsab wrote:This looks like a bloody good solution... if it works??
http://www.thunderpole.co.uk/cb_radio_guide_cb.html
good info here for a cb virgin
remember its the aerial that does most of the work not the radio
a short antenna will give you poor range 2 to 3 miles and a pain in the arse to swr
hobgobblin
- CB Handle: Hobgobblin
I've been reading all the comments on this thread and I must advise you to get a proper antenna! All the guys on this forum are right: it's the antenna that's going to make ALL the difference!! I've got a big one (Wilson 5000 Trucker) on a beehive mount and I don't hang around and have no bother whatsoever....it's NOT discreet by any means but it IS fantastic for range, i.e. 9 miles is clear as a bell, mobile to base. And I live in an area that is quite a challenge for radio communications!!! Hope you make the right decision...
HOBGOBBLIN
yup i think if you are on a rally then communications are more important than looks would be like getting a assistant who looks good but cant do the job against a dull looking expert or put more simply whats the use of a lifeboat with a hole in it
