How well would a mobile antenna work as a homebase antenna
spectra
nice one thanks for that, thats the one i,ll be having + pole, cheers
Ande
i don't get the ground plane thing, what is the ground plane? I'm going to get a silver rod myself but what's the best way to mount it?
aground plane is the the opoisite to the antenna if you can imagine a old fashioned weighing scale on of the arms is the antenn and the other arm is the ground so they both have to be the same length to get the antenna to work properly
with a silver rod mount it on a 6ft pole and this will act as a ground plane and the antrenna will swr dead easy
hope this helps
:D :D :D :D :D
Ande
i'm probably being thick here but if they have to be the same length, why does the pole have to be six foot if a silver rod is like 18 foot or somthing?
all to do with multipules of the wave length full wave is about 36ft so use multipuls of that 6 ,12,18,24,30,36 etc
