Alan EC 94 echo chamber
barbelmadal
Cor blimey,
please has anyone got the output lead wiring legend for this as I bought it from a well known CB shop and was told over the phone that they do not give out wiring patterns even though they had wired it incorrectly.
The coloured wires are as thus:-
Shield (common)
red
white
blue
brown.
Any help would be appreciated,
Thanks,
Al
what is the rig and what does the mic do when you plug it in
and what colours have you wired to what pin
barbelmadal
the rig is a pres lincoln.
When the output lead is connected all I get is this horrible screaming noise.
The mic goinng into the ec is a sadelta m 2002 .
All eq and modge sorted itseems like iffy wiring.
Hence request for wiring legend,
All the Best, Al
barbelmadal
please excuse dodgy ty[ing
lincoln only uses 3 connections looking at solder side of mic plug
bottom right = shield
one above = audio
one above that = tx
hope that helps
