Advice needed please
paradox
I am toying with the idea of using a thunderpole 5/8th wave aerial and a 6ft pole mounted on my chimney by means of 3 seperate lashing kits.
What i would like to know is how safe would this be with regard to high winds?
also our tv aerials are mounted on the chimney allready and i would like to leave them there but would i end up bleeding over our tvs everytime i transmitted?
Any help regarding this would be greatly appreciated.
Thanks in advance.
use 2 lashing kits 1 top 1 bottom and mount tv antenna to the pole as well if you get the swr right you should be clear with the rf on the tv
paradox
What about on ssb will it still be fine then?
yes should be ok if swr is right
paradox
Thanks for the advice
no problem another pint on the list
:D :D :D :D :D
