Confused
DaffyDuck
Hi All,
Recently started street taxi,ing and decided to get a CB to keep in touch with fellow drivers. Was advised that price etc made no difference to power / quality etc and was sold a Midland 38 plus sirio mag mount.
Tow of my pals have also just bought rigs and can talk to each other at far greater distances than I can. I can here them clearly but they can not here me until I drive several miles closer.
One has a magnum 257 and the same mag mount / antenna as me. They both purchased new and believe the rigs have not been modified in any way.
Have I been diddled and does price really mater or am I missing something. As I say, I can hear them loud and clear from say 6 miles away on a regular basis but they can not here me until the distance is down to 3 miles.
Any help appreciated.
You havent been diddled, but if your friend has a Magnum 257 then it will give a further range as it has 30 watts output power!
If you are using them round town in built up areas then the range is cut down but I would probably expect slightly more than 3 miles.
Which Sirio mag and antenna are you using though? And have you had the SWR checked?
DaffyDuck
Andy,
Thanks for the quick reply. The antenna just says cb line sirius and is black with a red band. The mag has no markings but is large and flat. Think they cost £27.
The shopkeeper didnt tune the antenna as he said this was done at the factory? Presume this is what the swr does?
When you say the magnum is 30 watts output, I thought you could only have 4 watts output legally?
From your reply I assume that the only way I will be able to communicate with him is to buy the same cb?
Cheers Andy
Round Baler
Hi Daffy.... The Sirio magmount you are talking about sounds like the Sirio ML-145 magmount.
In the U.K. you can only transmit up to 4 watts 'legally' but it dosen't stop people from going higher!
Would be better buying yourself a SWR meter from here as it always comes in handy.
Hope this helps!
- Gordon
Round Baler
"We Cut The Crops That Feed The World"
Basilsparents
I personally like my 7.5 watt rig... just gets you that little bit more punch over the hills... but sssh, don't tell anyone ;)
Round Baler
I bought a 100 watt Midland burner last year and I have never used it as I need another power pack to run it!
Don't tell anyone :roll: ...
- Gordon
Round Baler
Basilsparents
I have a wonderful 13 amp power pack. Came off some sort of ship :? Works nice, though
Round Baler
I'm nut sure how many amps I would need to make it run good! 10 amps min I would say?
- Gordon
Round Baler
DaffyDuck
Hopefully problem might be solved. Midland CB stopped working last night and local paper had a Magnum S9 for sale at 125. Decided to buy it and will test it tonight.
Guzzy
CB Handle: Guzzy
DaffyDuck wrote:... local paper had a Magnum S9 for sale at 125.
Sounds way too good to be true (£300 retail?).
It would sell on ebay for considerably more than that. So it's either a con job (someone trying to sell a broken one) or it's stolen...
Buyer beware :!:
DaffyDuck
Bought it from a little old ham man up in the hills of consett, apparently he bought it 6 weeks ago from a cb shop in the local area that was closing down.
Although he had been using it as a home rig, he had all the boxes etc and it has totally solved my problem, works like an absolute dream.
Guzzy
CB Handle: Guzzy
DaffyDuck wrote:Bought it from a little old ham man up in the hills of consett, apparently he bought it 6 weeks ago from a cb shop in the local area that was closing down.
You lucky bar steward! :lol:
