i work for myself ...work when i want tostampman wrote:unfortuneatly got to work so driveing in it low revs high gear seems to work
Snow
Had a bit of snow in Northampton, beginning to thaw now
BTW the cage in the background, we grow our own veg, last year our brussels sprouts were eaten alive by caterpillars so thought id build a mesh cage to stop the cabbage white butterfly [-o< no such luck, however at least this year we did have enough sprouts for Christmas dinner!
BEER IS FOR LIFE,NOT JUST FOR CHRISTMAS!
26-TM-1969 - Red Squirrel - Spinney Hill - mpcapri - more aliases than what's his name
porky.69 wrote:hi there mart is that the sirio 827 antenna
Yes sirio 827,FISH wrote:it was like my beam about a inch of all over it,do you get out well with the 827 low down.
Found it works ok being low, it works the same as my A99 with fireup top section and radials which is about 14 foot higher
(the sirio is only on a 4 foot pole - the A99 is on T&K brackets, the radials are just above roof hight)
Will swap the antennas around soon, the sirio will work even better being higher up.
Also got a 2 element beam to play about with, its for the 10 meter band but can be adapted to work on 27meg
Trouble is 'we are running out of garden space'
