Back after 20+ years!
dantek
Hi everyone
Back on the mic after 20 odd years.
Just set up my mobile rig, Midland 78 plus and mini stinger tornado.
Now, I have an annoying pulsing noise on channels 1-25ish, a real fast beeping noise
any idea? could the rig be faulty, it is supposed to be refurbished.
Any help greatly recieved.
Only heard a couple chatting on ch22 very distant and hard to hear due to this pulsing noise.
Mark
FISH
I DUDE WELCOME BACK....
26 TANGO MIKE 501
is it there ifyoutake the antenna out and have the engine switched off if so it could be faulty try various locations as well if it stay constant then it could be the rig
dantek
Still there with engine running,
Its like a fast morse code
stop the engine if rhe morse disappears then it sounds like spark plug leads are failing
dantek
Narh its a diesel mate!
Been out today and as soon as I get out of my drive the noise goes, so its something around my house, wifi signal or summat.
Anyway, whilst out today I tried a copy and 1 came back but said I was way over modulating and could I turn the mic gain down, cant do that on my rig, mmmm
Then I noticed whilst my satnav was charging it gave a 2 bar noise on the signal meter, disconnect and it goes. Have yet to try a copy with satnav disconnected.
could this be causing the over modulating?
I run the rig on a cig adapter, plugged in to a 4 cig adapter that also powers my satnav.
just talk farther away from the mike and a bit quiter experiment till you get good audio reports the local interferance could be a bt hub near you
dantek
Yea, its my BT hub!
OK tried it today with my satnav turned off and got better results.
but some said I was still a little distorted.
I've tried talking quieter, further away etc, no difference.
could the rig be faulty?
Mark
yes could need the rig turning down a fraction or a new mic
dantek
ok sent it back, we'll see what they say
now off air :cry:
FISH
hope your back on soon working 100%......
26 TANGO MIKE 501
dantek
ok, just found out they have refunded me as they said uneconomical to repair and they have no more in stock, so..
what should I get? dont want to spend much more than £60
maxom cm10 very good rig
dantek
Which one of these would you choose?
Intek M-790 Plus
Maycom EM27
Midland 98 Excel
TTI TCB - 881
TTI-TCB-770
Cobra 29
or the Midland 98+
anyone?
