midland 98+
dantek
ok got myself a midland 98+
secondhand and didnt get a manual.
I notice it has a scan button on it, but when I press it it only scans the 40 channels once then stops back on the original channel, is this correct?
I thought it should continuously scan round until someone is heard.
It doesn't stop on the channel when someone is transmitting either.
anyone?
could be the design of the set if the squelch is set to high then it may skip a low signal
Firetrap
CB Handle: FireTrap 26CT100
The Midland 98 only does a single scan cycle which is a bit of a let down really!
I bought one for Mobile use but sold it after 2 weeks, I rate the lower end team rigs above the Midland 98
