swr
- killer cam
- - - -> CB God <- - -
- CB Handle: killer cam
randombod
- CB Handle: randombod
quick question as this swr is still bugging me - i have earthed it in 3 different metal to metal places soldered and re soldered plugs on the extension and i can only get swr of 5 on the fwd setting on ch20 is this accepatable or damaging? its that quiet up here i cant get anyone on the air to check
best explain the antenna set up:
its a freelander with a metal bracket on the spare wheel the rig is on the dash and i have an extension bit linking front to back with a female to female connector in the middle (starting to wonder if its this 5m cable and shouldl i get a new one with a professional plug fixing) there is an earth from the bracket to the metal work of the car the antenna is a 4ft springer no matter what i try i am getting 5 on the swr....
Dumb question - You do know how to use an SWR meter?
switch meter to ref and key mike then adjust meter to set position, release mike key.
swithch meter to fwd ,key mike and read SWR.
last post you said it was 5 on chan 20
1st post you said it was 2 on channels 1 & 40
I know of no problem that would explain such readings except operator error
randombod
sorry i am another user with a similar swr issue i maybe shoudl have posted it on a new section not here i tested on ch20 and the guy on there also has been using ch1 and ch40 so 2 diff people with 2 diff problems
My apologies - I didn't notice you weren't the original posterrandombod wrote:sorry i am another user with a similar swr issue i maybe shoudl have posted it on a new section not here i tested on ch20 and the guy on there also has been using ch1 and ch40 so 2 diff people with 2 diff problems
An SWR of 5 isn't acceptable so you will need to find out what is wrong. I would start by movinng the twig nearer the radio and trying with and without the extension in line, that will show if it is a problem with the extension or not.
