Only had it setup for about a week with this antenna so still in the early days yet of telling what it can do.
Bout two years ago I had a 3/8 silver rod bout 6M above chimney very effective could get from Worthing, west Sussex to Brighton no prob and skip was great when it was happening.
From what Iv heard of it so far, Its a good clean in and output-er I recon 2.5 - 3 Mile most days. swr about 1.2
It's the height you want that gets the signals in and out there
my neighbors are a bit fussy though so gon stealth ... well for now anyway. Sam
Did some more pic's for you hope there what your after. Only some today though http://www.photobucket.com was running very slow today so only got a few. will post the rest when I can. Sam
As high to the roof as pos 1/4 wave
Bracket Holding Antenna at plastic section. Top and bottom connect at this point via mid tubing. Not very strong for bad weather though I would have thought, But not a prob for me
I made an Up pole with a base. Drilled base to fit Pole then drilled holes to ways. Then threaded steel wire both ways. With pliers twisted Loops for screws at base. Then Tightened screws so wire was taut and pole strait
Right next to a florescent but doesnt seem to be a prob
Home Made Mag. Well a Rad Maybe dos the job though
