Siginal Meter Hits 30+ on TX
Daedalus
A week or so ago I managed to rescue a old Rotel RVC-240 from a friends shed with the intention of restoring it to its former glory!
The radio hadn't been used for at least 3 years, but before it was put away he was in daily contact with me on it.
I've just now got round to powering it up and have started to 'have a look at it'. RX seems to work fine, I've received a few signals but when I key Up the Signal Meter Hits 30+ as if there was No antenna connected or there was a short :/ Flick the switch to Low Power (-10dB) and the radio seems to TX correctly. The signal Meter Moving to the correct point on the scale.
I haven't been able to make any contacts though.....
These day's I don't have much in the way of test equipment for CB radios so I was wondering if any one knows any possible causes for this??
HARRIER - CBX ---quality CB built on the famous Cyberrnet 134AOX board.
'Breaker One-Nine, what's your 20? I Hammer'd Down on the A3
I eyeballed a Kojak with a Kodak so I pulled in behind a Suicide Jockey.'
Rotel RVC 240
Definately check the SWR with a meter first but the needle deflection can be adjusted inside .it should have the same PTBM134AOX board as the beta 3000 and Harrier CBX ,trim the key up adjustment horse shoe till the needle is at about the + sign.
if you can hear someone and they cant hear you it could be a mike fault on the out going audio dont worry about the meter sounds like somebody has turned it up thinking it will give more power but do check the swr for a start
Daedalus
Checked the SWR, it wasn't perfect but acceptable, Switched mikes with another radio same thing still happens.
I'm starting to think there is no actual fault with the radio other than what could be a broken meter- The 5/8 wave antenna I'm using is fairly old and the Coax has seen better day's. I'll see if I can pull out another rod from some where, even a mag mount and try it on that!
If your silver rod has a section missing then the SWR will be way out,check inside the antenna as sections often fall inside when they become loose.
