Hi there - Amateur here! Just bought my first CB radio today, a basic budget M**nraker Minor UK 40 and I was recommended an Aerial to buy - A M**nraker Skyscan. As I'm totally new to the scene I will no doubt be asking lots of questions! If anyone has any advice on my purchases I would love to hear !
Anyone else in the Surrey Area?
Hi from Surrey!
hi and welcome depends how good you want the setup to be always spend on the antenna for best results other wise its personal choice i use the wilson 1000 and have done since they were first imported will even do some hf bands
datadabbler
Eviltwin wrote:Howdy, welcome to the forums, I presume you're planning to install into a vehicle?
hello eviltwin-forum and anyone else viewing,
re your reply, ( please dont be offended im new ) you say presumably your planning to install in vehicle,
only i notice in gallerys there are pics of home rigs, is this version discussed in the post better for,or only for vehicles ?
or can it be used in house, im monotoring new rig posts before i jump in,
now i have firmly grabbed the wrong end of the stick. please feel free to slate me , lol, oops
many thanks
LimehouseJack
Eviltwin is indeed correct - its going into a car for a group trip down to the Nurburgring (but I may also have it set up in my room for when Im bored
It seems I need some kind of connector for the aerial to attach to the CB rig ? The aerials website says its Connection: BNC male which seems incompatible with the CB back ? It seems I may need something like a PL259 but can anyone confirm or deny this ?
Cheers and thank-you to all for a sterling welcome!
As far as I know most CB's do indeed use PL/SO239 connection for the antenna and associated cabling.
After looking a little closer at the skyscan, is it the one with something like 4 antennas from one base? I get the sneaky feeling that its not a CB specific antenna. I think its meant to be used with a scanner, which would explain the BNC plug. You possibly could get away with using it by making up a patch lead, but I wouldn't chance it (the wrong kind of antenna can damage your rig beyond repair), sorry to bring bad news, but you may well have to return it, and get one that's meant for CB usage.
When picking an antenna, the quickest and easiest solution for trips like you're planning, if you don't need a permanent install, is to go for something longish (generally more range) yet still fits in your car when you take it off, with a 3/8 screw thread, and use a mag mount (unless your cars an aluminium or composite bodied racer then you'll need something a little more permanent). That way when you get to the ring, you'll be able to pull it off quickly for better aerodynamics. Oh, and remember to check the SWR of your antenna so you don't destroy your rig (really bad SWR is as harmful as the wrong kind of antenna). Also fitting a cigarette lighter plug will make for easier fitment and removal in your car, just wedge it down the side of a seat while you are using it.
One other point to be aware of is your minor 40 is only legal to use in the UK (80 channel units are generally ok as they usually have the UK and Euro 40 channels). Chances are that if you use it in Europe you won't get caught and no one will be any the wiser, but its better to know in advance, the German rozzers are buggers for on-the-spot fines if they are in a mood.
Have fun at the ring, but come back safe.
If you are traveling fast ( above 70mph ) buy an antenna with a low wind resistance and a large magnet mount. http://www.thunderpole.co.uk/fm27.htm
large bulky antennas can blow off the roof .
The (other company) Skyscan is indeed a mobile Scanner antenna and no good for CB radio Transmittion .
LimehouseJack
Ok so second trip to the shops and I've switched the skyscan for a tornado stinger CB aerial. Also got myself an swf meter in order to get it all going. I've wired up the CB on a cigarette lighter doodad and thats working. Now I go to use the swf meter I realise I need a PL-PL lead. Back to the shops I go! Third time lucky!!
LimehouseJack
Got my CB rigged up to my SWR to my aerial. I've it adjusted so when I transmit its only going about 1 / 1.5. Next question is - how do I know if its working ? I mean - if no one is around with a CB how can I tell if I'm doing it right and transmitting? Do most people chat on 19 or somewhere else?
EDIT: Also - I guess I should be asking these in the tech help section not here. Thankyou to all for your help anyway!
Remember to take the SWR meter and patch lead out when you're trying to transmit, they sap a bit of your 4 Watts.
As for making contact, if you live out in the sticks, take your car out for a spin to a local town one evening. If you still get nothing, try asking for a "Radio check" on channel 19, you'll probably find a lurker who'll let you know you're making contact.
