a new home cb ?
CB homebase advice and troubleshooting
datadabbler
hi
just looking around at cb set ups, the one advertised on here for example T-1000 ,
im not worried at this stage if its good bad or average,
my question is if i want to use at home will i need a seperate power adpter for using via the mains, or do you need a battery pack,?
thanks in advance
seperate power supply is best (does not go flat)
Eviltwin
I wouldn't bother with batteries in the house/shed, its just plain messy, and you'll need a form of power supply (battery charger) to keep them recharged any ways.
Theres plenty used ones on a well known auction site, or If you find an old PC going spare, then you can rob its power supply and use that with a little effort: http://www.thunderpole.co.uk/forum/view ... f=5&t=3189
datadabbler
aye fair points, ive got loads of pc,s im sure i could cobble a psu, unit off one( i am qualified to scavange off pc,s lol )
thing is now im looking at ham radio too, it just goes on dont it,
msaybe i could do both, :wink:
The PC power Supplys only give 12volts so you will find that your radio is only showing around 3 to 3.5 wats on transmit , as against using a propper power supply 13.8 volts which will give you 4 to 4.5 wats on transmit, but it will get you started until u can afford a propper supply.
datadabbler
Hey Dragonfly,
thanks for your reply, do you think performance may reduce with the psu unit, does the wattage make a big difference?
if you dont give it the amps then it aint going to work that well cb'2 are designed to be most efficent at the charging rate of a car or american truck which is 13.9 volts anything less will of course affect the performance of the set
