cd radios, no power
illegal operater
hi
dug out my old radio gear, was going to fit in the landy, though the 1st rig doesnt seem to power up,,,and when i tried the lead on the other rig,,the other worked. So its not the inline fuse.
Used to use a dood in clydebank to fix ma rigs years ago,,and a dood in erskine, but im stumped, and would like a bit of info in tracing the fault myself.
1st rig is a Maycom EM-27 80 channel mobile transceiver,,,doesnt power up, been lying in loft for13 years.
2nd rig is Uniden pro450e, lighting up and sound,,,but digits are broken up.
thanx much
iain :mrgreen:
The Uniden Pro 450e is a mid band only radio ,no UK 40. And i think the old Maycom EM 27 will need a priest and a miracle .
Hi Iain,
The older Maycom EM-27's had a rechargable battery in and if left for a long time the battery would leak onto the board giving all sorts of problems, so it could be that.
You will soon see if you open the lid. Look for the green battery and see if it has corrosion around it.
If it does Dragonfly is probably right about the priest and the miracle!!
illegal operater
hi
Thanx for the replies guys, was sort of thinking the same,minus the priest though.
Dragonfly, was wondering, "mid-band" would that be AM, thanx in advance.
Think if i cant get the maycom working, il search and see if a can find me old favorite,,,a ham concorde 2
Andy i defo will have a look tonight and see if its a wheeping cell
once again thanx for the replies.
Iain :mrgreen:
il need to see if any of the breakers i used to talk to in glasgow, clydebank area, are on here,,Top Forum Andy
illegal operater
opened up the rig,,and no wheeping from the battery,
though i noticed a small black and silver barrel shaped component has burnt legs AND IT SHOWSS ON THE SOLDER
think it says 00h on it
location is next to a thing that has copper wire wrapped round it and yellow tape over it
thanx
iain
Fat Rat
Hi, maybe this will help you identify the component/s
This is the link if the image doesn't show... http://www.jonshouse.co.uk/em27pcb.jpg
The Uniden pro 450e is cept Mid band FM radio covering 26.965 to 27.405mhz
illegal operater
Fat Rat wrote:Hi, maybe this will help you identify the component/s
great pic..though my batteries 6 times bigger.....Anyway see that square thing with the ylow plastic.between power plug..and coaxial plug
well its the small barrel immediately to the right of the square yellow thing..near the power plug
im a bricklayer...hope u understand what ive said
many thanx to all the posters
iain
post us a close up in focus pic of your problem area good bud.
if its the barrel that has swelled then ther has been a voltage surge through the set
