Interference problem in New Holland 6080.....Please help.
stewartyboy01824
Hi there, i am in desperate need of some help and advice from you guys!!!
I have a serious interference problem in my New Holland 6080 which has been driving me mad now for 2 years!! I am at the end of my teather and need all the help and advice i can get. It is so bad its hardly worth having and makes the cb pretty much unuseable as soon as theres a bit of distance between me and someone else! I have been into cbs now since i was a little boy so i know the ins and outs, but this is a problem i cant seem to fix.
My interference problem is not one that shows up on the signal metre but its a noise thats constantly there every time someone is speaking to me, its hard to explain the noise but its like someone constantly farting ha ha or a tick tick tick tick kinda noice, its so bad it overpowers the voice thats trying to speak to me as soon as someone gets a bit of distance from me!! So its ok if we'r in the same field together but two miles down the road.....forget it, i cant understand what there saying!!!! I can transmit fine with no problem!!
So, If the tractor is off the cb works perfect but when the tractor is on theres that horrible noise when someones speaking......now heres the funny bit.....if im coasting down a hill so the engine is under no strain the noise goes away and the cb works ok, its every time i put my foot on the throttle or when the engine is idleing or im working in a field or roading normally, its hopeless.
Now ive tryed moving the aerial several different places around the cab and mirrors, ive tryed 5 or 6 different cbs in different places in the cab of different age and technology, ive tryed wiring strait to battery, ive tryed one of those power supply bandit filters, and nothing seems to make a difference!! Im going to try a Cobra 29 LTD ST Nightwatch next to see if old technology but with good filters might help.
I first thought the interference must be coming through the power supply as theres no signal meter showing it, and with the electric foot throttle being relevant to the interference it must be electrical, or maybe it could be the fuel pump??? or the alternator??? i just dont know!! But after trying out twin aerials a while ago the noise seems to be worse, like twice as bad, so thats got me thinking that it must be coming in through the aerial?? or could it be coming in through the earth?? i just dont know!!!
I am at the end of my teather now so any advice and help would be much appreciated, it would be such a shame not to have a cb in my tractor now, i cant imagine working without it.
So if anyone can shed some light on where my interference might be coming from or what might be causing the noise and how to fix it, i would be very gratefull!!! or maybe one of you has had a similar problem?
Thankyou very much, i look forward to hearing some of your replys. Stewart.
Offplanet
Sounds like fuel injector noise.
Ferrite rings on the wires to the injectors reduced the noise considerably on my van.
stewartyboy01824
Thanks for that advice offplanet, could you tell me what these ferrite rings are and where i might be able to get some? i think ive heard of them before. Many thanks. Stewart.
Thunderpoll do some ferrite clamps and an inline noise filter - http://www.thunderpole.co.uk/cb_accessories_misc.htm
Maplins do a range of Ferrite rings http://www.maplin.co.uk/ferrite-rings-and-beads-32792
Eviltwin
The lower pic shows a ferrite ring for each injector with the red wire wrapped round it. Simply you take a wire you believe is causing interference and wrap the wire round the ring, and it suppresses any radio interference from that component. Its a cheap yet fairly effective method of getting rid of unwanted interference.
You can get them from loads of places:
This site sells ferrite clamps you simply snap over each wire,
Your local CB or amateur radio store,
A well known auction site,
Maplins have loads of things ferrite.
Just search for Ferrite, and you'll get loads of hits.
May even be worth getting one for your CB's power lead incase there is any interference in your electrical system.
stewartyboy01824
Thats great, thanks very much for all your advice, il definatly check out these ferrite rings. I have seen a pack of 10 of TDK clamp on ones for around £10. Would these be sufficient??? I would need 6 for my 6 injectors so id have 4 spare for maybe the alternator, fuel pump and power leads for the cb etc etc. and would it be worth putting one on my aerial coax cable? Many thanks. Stewart.
