Without the radio on, it works perfectly. With the radio on, the rig picks up interference from the ignition.
My setup is:
MIdland 38
7" Magmount
Stinger antenna
Stereo is:
Sony headunit
Fusion 600w 4 channel amp and 6 speakers.
The thing that puzzles me is that they aren't wired up to the same feed. The headunit uses the accessory feed and the amp uses a feed direct from the battery (switched on from the headunit). The rig gets a switched ignition feed. I think that they may use the same earth point, however I can't remember as I put it all in a couple of years ago and I have had a few beers since then
The car itself shoud be quite well supressed, its from 1994 and is wired up more like a Rover Metro (not the best example I know haha) rather than an old Mini with ballasted ignition and a supressor on the coil. I also very rarely use the FM radio as I mainly listen to music stored on a USB stick.
The only thing I can think of is that the RCA leads from the headunit to the amp run behind the CB, but there is quite a gap and the co ax and RCA's are both only 2 years old. Can I fit an inline supressor to my rig?
Its not a major issue as when I've got my rig on, I'm usually convoying or doing a treasure hunt so I don't have my stereo on anyway! I would really appreciate some help though cheers!
