Hi all me and a mate bought a pair of Midland 77-099 from a well know auction site, it said that they were both in working order if not a little bit worn..
So we set about and fitted them into our Discos to be used whilst out and about green laneing etc.
My set-up is as follows:
Unit up in the roof in the map pocket powered from the interior light supply, then its a short run of RG58 cable with a clamp fit PL259 on either end, to a:
Base-loaded CB Mini Tornado Stinger Antenna
Frequency: 27-28 MHz
Power: 1000W
SWR: 1.5:1
Fitting: standard 3/8
Length: 88cm
When i do a SWR reading i hook up the meter as described in the instructions and carry out the test, turning the "CAL" knob doesn't do anything and when i take readings on different channels the needle move ever so slightly above 1. The SWR meter is:
(other company) SWR-100 CB meter
Frequency: 26-30MHz; impedance: 50 OHMS; connection: 2 X SO239 sockets
when i turn the Midland on when it is all connected to the antenna and not the SWR i get power and a very faint static noise if i turn the squelch to about half way, but you need to put your ear near the speaker to hear it.
I am now at a loss as to what to do next, i have been told to get the unit tested but i cant find anyone near me to take it to (Kent), can i start testing the unit myself i have a multimeter and access to some other equipment if needed, i just need a place to start really..
Rob
Midland 77-099 Problem
side-show-bob
Ok so i may have made a mistake,
It is a custom made bracket attached to one of the roof rails on a Discovery, but there is a rubber strip between the bracket and the roof bar. Dose the antenna need to be earthed as well as the radio?
Hi Rob, R U sure that the interior light fitting is capable of providing enough power for a CB? Even a little Midland like that will want two or three amps. Try the radio using a cigar lighter plug to see if it does the same thingside-show-bob wrote: powered from the interior light supply,
side-show-bob
Ok so an update, i have just checked the mic and found that the earth had come off so now i have sound when the unit is on, i get white noise when the squelch is around min and then nothing when moved to max is that correct?
If the needle is hardley moving on the SWR meter check the power switch on the back of the CB , It needs to be on high output power to move the needle properly.
Roof rack should be earthed to the Disco body for best groundplane .
I have found that the 77.099 midland will misbehave if it has no 2 amp fuse fitted but if it is recieving ok then it should transmit ok .
