446 mods
needle bender
Is it worthwhile doing the 4 watt mod to a 446???...the drain on the batteries at 250 milliwatts is bad enough...what gains for 4 watts...??? :)
sounds like you are going to need backup batteries in your pockets
Guzzy
CB Handle: Guzzy
needle bender wrote:Is it worthwhile doing the 4 watt mod to a 446???...the drain on the batteries at 250 milliwatts is bad enough...what gains for 4 watts...??? :)
Before even thinking about modifying a PMR446 radio to output 4W, make sure you have upgraded the stock antenna to something decent (ie. That works!). Otherwise, you are wasting your time.
Most PMR446 radios actually TX at slightly more than 0.5W, they just lose it all in a very lossy stubby (spring design) antenna. Putting on a decent UHF antenna can make a phenomenal improvement all on its own.
