Hi, I have just installed my Midland Alan 48 plus, into my Renault Kangoo. I am using a 7inch mag mount, with a Thunderpole Atom, i have placed the mag mount in the centre of the roof. The problem is, i am getting a SWR reading of 3. I thought the Thunderpole Atom, was low SWR, should i cut the areial down, if so by how much, as i don't want to take to much off it, also what is best to use to cut it, hacksaw etc ?
Any help and advice, will be much appreciated
Many thanks
High SWR reading
- Andy Nazel
Hey Woody! If the SWR is higher on ch40uk fm than channel 1uk fm then it needs cutting if its 3 across all channels then I would look at the mount and cable for shorts or broken connections.If these are fine then try using an old wire coat hanger cut to the same length as the atoms whip and make your mistakes with that before cutting the original.Coat hangers are a softer alloy than stainless steel which makes it easier to cut a few times till you get a good SWR and then you only need to cut the original whip once.I would make 1cm cuts to start with and when the SWR starts to drop take smaller bits off till you hit the mark.
Hi Andy, Many thanks for your reply and advice. I will check all connections, if all ok, then search for a wire coat hanger.
I must admit, it was not going up to 3 on all channels, so maybe, hopefully i just need to cut it.
Thanks again
Thanks again
I have now cut nearly an inch off the aerial, but now i am getting a reading of 2 up to channel 15, then past 15 it then creeps up, until i am still getting a reading of 3 at channel 40. I moved the aerial further to the back of the roof, rather than in the middle, i don't know if this also made a difference.
Should i cut more off the aerial ?
I have also noticed, when i use the mic, the lights on the radio go dim, is this a short problem ?
Many thanks
Many thanks
- Andy Nazel
Hi again Woody,if the SWR is coming down as u cut then I would keep cutting.Middle of the roof is best,back of the roof makes the aerial somewhat directional,signals in front of you will be good but those behind you will struggle as I've found out on my car.The back of the roof was the only place I could drill to fit the mount thanks to the way Ford builds Fiestas.As for the lights dimming,does this happen with the engine running also?If it does then its probably just the way the radio is.What rig are you running?Maybe someone else has come across this.
as long as it is higher om ch40 then keep shortening but stop when the swr readings are the same on 1 and 40 try moving it around the roof and check all swr's with all doors shut
