New Van..New Problem...
Bionic Budgie
CB Handle: Bionic Budgie
Hi Folks...
Me again.. \:D/
Its new van time..my trusty old 55 plate Transit has served me well for the last 6 years and has now gone to the Knackers Yard (or could it be Dale Farm?)..anyway..I have taken delivery of my new 61 plate Ford Transit and spent the last 3 days putting my gear in required for work. Yesterday I got round to putting my CB in..firstly..Ford have yet again come up with a dash board with nowhere to fit Sat Navs, PDAs, Phones and all the other stuff I seem to need now days to carry out my work..... CB,s ended up in the ashtray!! Popped my Wilson 1000 Mag Mount on the roof (too early to drill a hole in roof) and fired up the rig...engine off all ok, start the 2.4 diesel and..OMG! SSB/AM..S9 of shite..FM not much better :cry: ...due..as far as I,m aware of the solenoid fired injectors...HELP! Has anyone out there had this problem and solved it?
Bionic Budgie
Diss 20
check all earth's if it whines when speeded up its the alternator
Bionic Budgie
Thanks for the reply but it's not alternator. The 'clicks' are caused by the solenoid fired injectors that are now fitted to model vehicles. :(
Offplanet
Try some ferrites on the wires feeding the injectors (as close to the injectors as possible).
Adriano9966
:) how are you powering this cb eg are you powering direct from the battery???
If you are try using screened cable and then earth both ends of the outer braid to the body of the vehicle.
:) This cheap solution should act like a farady cage which will limit (at least) or eliminate(at best)some of the interference
try this as well as using ferites
hope that helps kind regards Adrian
