...OK, the mobile CB antenna is up, fixed & working great.
But I now want to run a separate scanner (to be used for CB channels only) in the car. Can I just use a "splitter" at the CB end of the antenna cable and run a short length from the "splitter" to each of the two units, or would I be better off installing a dedicated antenna specially for the scanner?
And, if the latter, any recommendations would be gratefully received.
Thanks in advance, chaps, B
...and for my next (ignorant) antenna Q...
- AdvancedRoadcraft
- CB Handle: Golf Zulu
Best, B
(Barry = "Gulf Zulu")
needle bender
Hi,you say you want a scanner just to monitor cb channels???...well why not use a cb transceiver with scan capability...or are you looking to scan a more comprehensive range of cb frequencies...freeband etc???
- Andy Nazel
Hello!
If you just use a "splitter" then the 4watts from your cb will go straight into your scanners aerial hole when you key up and kill its recieve circuit!!
Best to use a separate aerial.Check out Thunderpoles range to see which one is best for you but I've used a Skyscan Mobile and had no problems the only thing is the" multi- antannae" arrangement does draw attention.Was once asked"Are you TV Licensing"
- AdvancedRoadcraft
Because I've got a (non-scanning) CB unit that I'm happy with and don't therefore want to swap just to get one extra feature!needle bender wrote:Hi,you say you want a scanner just to monitor cb channels???...well why not use a cb transceiver with scan capability...or are you looking to scan a more comprehensive range of cb frequencies...freeband etc???
Best, B
Best, B
- AdvancedRoadcraft
That was a circuit description that even I could understand!Andy Nazel wrote:Hello!If you just use a "splitter" then the 4watts from your cb will go straight into your scanners aerial hole when you key up and kill its recieve circuit!!
Many thanks for saving me an expensive mistake; I'll do as you suggest.
Best, B
Best, B
if you ring Colin at our sponsors they do a splitter that you can use it taps the signal from the cb antenna to your scanner without aloowing the tx power to download into your scanner
