Thunderpole Triple loader Amazing
Adriano9966
:D Hello I wanted to share with the forum my experience of this small mobile antenna which has completely bowled me over with its excellent performance.
I originally bought it (My thanks to Jumping master who recomended it) for the big net back in November.
my XYL got in a mood with my dv27 and got the end caught behind a kitchen cabinet so I needed an urgent replacement .
:D The thunderpole triple loader is a top loaded antenna with three loading coils and a small tuning whip ...Its a meer 1.3 metres long(4'4") so practical for mobile as well as static use .The reason I decided on this one was because it would fit inside my tiny Hyundai Getz just like the DV27
I have since been using this with my new mobile set up on ten metres and I have acheived the following with 2.5 watts ssb using the internal battery pack on my Yaesu ft817nd :shock: Moscow from a carpark in the middle of Banbury a couple more eastern Europe and last Sunday :shock: NEW HAMPSHIRE from a small hill near Stratford Upon Avon during the ARRL contest
:D I have some pictures here from another forum
http://www.transmission1.co.uk/forum/vi ... 25&t=24141
needle bender
Hi,i have tried and used countless antennas over the years and found that they are all of the same muchness really..base load ,centre load,and so called top load,,dv's modulators,sirio the lot...at the moment i'm using a base load modulator and an old cherokee..both about twenty year old and as tough as old boots..plus an old tank whip for static use on freeband...if conditions are really good you can more or less dx with a lenght of wet string...although 4 watts am to the states on mids has eluded me yet again this year... :D
nice antenna *King*
Adriano9966
needle bender wrote:Hi,i have tried and used countless antennas over the years and found that they are all of the same muchness really..base load ,centre load,and so called top load,,dv's modulators,sirio the lot...at the moment i'm using a base load modulator and an old cherokee..both about twenty year old and as tough as old boots..plus an old tank whip for static use on freeband...if conditions are really good you can more or less dx with a lenght of wet string...although 4 watts am to the states on mids has eluded me yet again this year... :D
:D I would have thought that the 1/4 wave tank whip would have the edge(slightly) due to no inductive loss through a loading coil plus a better take off angle
But I have been pleasantly surprised with this antenna which is quite short compared to other mobile antennas the top loading coil will surely give a lower radiation angle :wink:
needle bender
Hi,how well will the triple loader swr over the mid/uk 80 channels...???
Adriano9966
:D its not bad at all even at 28.5 its still 2:1(1.1:1 on 27.4) so it will cover both cb bands and the ssb portion of ten as well !
It would be possible to shorten the top tuning whip very slightly and make two marks on it with an indelible marker pen to have two different tuning ranges for ten and eleven metres but just to put things into perspective even at a 2:1 range the power loss from reflected power would be about 10% so at 4 watts thats a meer 400mw
needle bender
Ok,,i'm sold on it...will order one up after xmas and see how it goes..thanks for the info... :D :D :D
