Be very careful Harry .That pot is not the mic gain but the FM deviation turning this up SLIGHTLY will have the effect of a louder audio but you will then need to hold the mic further away to avoid over modulating...if you turn it up too much(usually all the way) your audio will sound distorted and you will splatter across adjacent channels
adjusting the fm dev can be done but you would be better off using in my modest opinion an fm deviation metre of sorts
I personally would avoid this as the fm dev set at the factory is usually just fine
when I was a young lad of 16(cue hovis music the journey home
) I once bought a second hand Uniden that had been ''TWEAKED'' to 8 watts and with higher deviation .......
I imediately got a local ham to realighn it to facrtory settings as I did not see the point of owning a legal transceiver that was not legal
