Linear amp/ burner
Redrage
CB Handle: Night cruiser
Hi again. Just a quick question about linear amps. If a max output 100 watt burner says input 1-10 watt does that mean that if I'm only giving it a 4 watt input will I only be getting around 40 watts. Many thanks Harry
in a word yes it works at 10 to 1 ratio you might even get less because the use a perfect set up to measure them
Redrage
Thanks for the help
oldskooldaze
know a guy in Aus that runs with 20w in and 1Kw out :shock:
