Newbie question no.1.......
fusil56300
Bonjour,
I've got 2 cb's in a swap for some old fishing gear I did'nt want. :P
Got a Harrier CB and a Harrier power converter, both unused and in original boxes. This'll be my home unit.
Also a President Valery, used but in A1 condition. New and unopened President Kentucky antenna, to be fitted in my van.
My 1st question is.......the fella I got them from had them wired up to car battery to show me they worked.
I then read in the booklet that it come with you should never do this as its will damage them! #-o
How true is this?
No.2, because of where we live it'll have to be a indoor antenna. Can I use a car antenna on the bench next to the base unit or in the loft.
Cheers for any advice.
fusil
use a mobile cb antenna with a ground plane wired to it to get the swr down and put in the loft for height i think the valery is am and the harrier is defiantly fm
Answer to question No. 1 - That's ridiculous! Most people use CB's in vehicles! Most CB's will work from something like 12v up to 15v (dependant on the radio).
only if you wire it + to - or to put it simply cross wire it
Good point Stampman =D>
fusil56300
Oh merde!!!!!!!!!
Forgot to say he did'nt have an antenna plugged in.
WHATS A GROUND PLANE???????
Merci,
fusil56300
Stick the magmount on a radiator or fridge or washing machine .
not the washing machine or the wife/partner/other half will have you doing some washing while your "messing about"
fusil56300 wrote:WHATS A GROUND PLANE???????
http://www.thunderpole.co.uk/cb_radio_g ... plane.html
fusil56300
Andy.....Vous êtes l'homme. =D>
andy think that's french for "do you want to be president"
Merci!
And no thanks :D
