Shogun 40ch Radio
- Andy Nazel
Hello everyone! I recently aquired a Shogun 40ch cb,have never seen this model before. http://www.flickr.com/photos/andynazel/ ... hotostream hope the link works as I've never added one before!! I can find no info on this radio at all,and it has a couple of problems.Problem one-someone has removed a diode http://www.flickr.com/photos/andynazel/ ... hotostream and added one to the print side of the board http://www.flickr.com/photos/andynazel/ ... hotostream why I am not sure,something to do with the "idiot diode" perhaps? Problem 2-The modulation adjust does nothing to improve the quiet outgoing audio(not sure if the pot itself is duff) however when turned fully anti-clockwise(down) it causes the audio to "buzz" and a power mic also sounds quiet(the power mic is fully working).Problem 3- When transmitting into a dummy load the radio produces 5watts but when connected to my aerial (a Gainmaster,swr needle sits flat on this aerial) the radio only produces 2 to 2 and a half watts but when I tried it on a mobile aerial with a SWR of 1.5 it produced 6 to 8 watts and as I raised the swr on the mobile twig to 2 the wattage output also increased but decreased as I SWR'd the aerial towards 1.2 which is confusing the hell out of me.Let me point out that I am not a complete "numbnut" when it comes to this stuff as I was once a TV and video(remember them?) engineer but CB's are a bit new to me and have fixed a few for friends and myself but I am no rig doctor.Any help,tips or advice would be greatly appreciated
D403 will be the reverse polarity protection diode and some one has fitted it to the other side because its easier . Dose however suggest that the radio has had a belt of 24volts or been wired back to front . You could try replacing the old large capacitors on the board ,If that brings no joy you can try following the audio track from the modulation pot you may be adle to link out or use a lower value resistor to raise the modulation signal .
