microphone problem
dc4
CB Handle: Doug!
hello! i got a replacement microphone the other day and when i plug it in and key it more noise comes out the mike than the speaker! im only replacing the original because it has a broken wire in the lead but i dont want to attempt to repair anything myself as that may end up cutting short my new hobby! lol! its a harrier cbx with a four pin plug, do they need specialist mikes?! cheers!
no the mic is wired wrong simply rewire it and all will be well in the world you can find the right way on here
1 = audio yellow
2 = shield
3 = rx black
4 = tx red
dc4
CB Handle: Doug!
ok mate ile give it a whirl as i can still use the old one if i hold the wire in the right place! lol
dc4
CB Handle: Doug!
problem cured in one easy step! i ordered and received a power mike from here and it works just fine now! i also now know the difference between standard and uniden mikes! lol!
easy way out but a good one
