mother in law! 10-4!
dc4
CB Handle: Doug!
my mum in law lives on the other side of basingstoke and im in guildford.that is about 40 miles away? anyhow, my current ambition is to be able to set myself and her up a radio system where she can call us and hear us if neccessary. obviously these will be two homebases but what equipment could do this on the 27fm without going too over the top price wise? cheers doug!
needle bender
Hi,guildford,Basingstoke,about 40 miles you say..well,radio waves travel as the crows flies so you could knock a few miles off that....much depends on the lay of the land between you and your mother in law,,are you both on high ground or in the middle of housing estates etc...can you get your antennas way up high...yeah in theory it could be done...but i would be inclined to say to you that really its wishful thinking..if you yourself are into radio set up your own station first and see what kind of range you can achieve...but if its just a case of keeping in touch with mother in law only,maybe skype is your answer... :)
Adriano9966
:D :D I think its possible but not without problems. I have looked at the satellite images and it seems to be mainly level ground between both points apart from Aldershot.
a simple 1/2 or 5/8 wave vertical antenna should be sufficient fed by reasonably good cable eg RG213 or RG8 (there are better ones which are a bit more expensive but with lower loss)
Mount this as high as possible in both installations .....the antenna is make or break for any radio installation so the more time and effort you spend on this the better the station
the type of cb transceiver used is relative as the antenna is the most important element
Its most likely that you will get this sort of range at night and if we are talking about 30 miles or so as the crow flies that is achievable in my modest opinion but not all the time
I hope that helps
dc4
CB Handle: Doug!
thanks for the info chaps! as you say needle bender i will set my home station up first and work it from there, still having a few technicalities with my mobile set up but should have that sorted soon. next thing i suppose is getting the right antenna to do the job, is an amtron 99 as good as people say or is there just as good alternatives that would do the same job?
edit: just seen the antenna thread! tut!
the new thunderpole 5 home base seems to be as good
dc4
CB Handle: Doug!
i had a look at that aerial last night on here and its not pricey at all i dont think. and having a fella say that its as good if not better than a 99 makes me think its a wise choice come pay day! going off on a tangent now, does low cloud affect radio signals? i tried out my tank whip last night at newlands corner standard 4watt harrier cbx and didnt hear an awful lot at all whereas the night before i tried it briefly spoke to brighton clearly outside my house, and it was clear.
Bionic Budgie
CB Handle: Bionic Budgie
If you can hear thru all the Russian Taxis! :(
needle bender
cb radio,,sometimes it seems the whole world is listening in,,and other times its like you are the only person around...propagation,,even the time of day can make a difference...but also some of the problem is people just listening and waiting....guilty of that myself at times...just going through the channels hearing nobody and giving up...try shouting on 14 or 19...which were the old calling and mobile channels..or try 31 on cept band...it seems to me that the british cbe'r has lost the ability to start up a qso....but dont give up..there are still plenty of old school cber's around.... :D :D :D
