Thinking about buying an icom 706 mk2, been offered one thats "faulty" as it receives fine but when you TX on 2M it only pushes out 2-3Watts and on HF it drops to milliwatts
Cameron
yes stampman , i agree on the point you make. my comment was mainly based on the amount of people , who have antennaes up inthe air, but choose not to use them much, but spend it mostly on the so called digital modes, ect.stampman wrote:echo ling is good if you can not put up hf antenna where i am not allowed to put up long wire etc so echo link does me fine horses for courses rely
jumpingmaster wrote:hi cam
ncie to see you got the callsign through , and on subject of first radios, i see you looking at the icom 718,
what you might have to consider is what bands you you want to use , as that mentioned radio is hf primarily, and wether you want to buy the vhf/ uhf radio seperately .
then there is the matter of homebasee solely or occasional mobile.
lot depends on costs involved.
amateur radio repairs are expensive, so i tend to stay clear of second hand radios with so called minor faults, ect..
there are a lot of radios on the market depending on ones approach to usage.
i use the yaesu ft857d for mobile use , or you might venture down the 144 / 433mhz route for starters.
whichever way you go , i know you'll enjoy it .
try to stay away fromthe echolinks, ect as real contacts are only made and enjoyed through direct rf contacts through your antenna systems , rather than internet aided lol..
i see a lot of chaps get on the echolink and lose the enjoyment of pulling a contact out of the pileups and lift conditions.
cheers cam have fun
73 ' s de joe
