Range
Brando
CB Handle: Mosquito
I have a Midland 48 Plus Multi installed in my car (direct power feed from the battery) with a Tornado Stinger and Mag Mount on the roof. The maximum my SWR goes to is 1:5 so why is it that I can only manage to transmit about a mile radius?
could be low power out of the set bad audio on the tx output high interference on the rx signal position of where you are
