help needed to construct and make an antenna
The Blues Man
CB Handle: The Bounty Hunter
Hiya fellas,
Just wondering if anyone can help me in my quest and attempt to make and construct a vertical antenna to cover both 10 & 11 meter bands ?
At the moment i'm using a homemade horizontal wire antenna that is attached to mine then my neighbours chimmney stacks but i'd like to make my own vertical antenna and lash it to my chimmney stack.
What parts and bits do i need and is it easy enough to make,any help at all would be truly grateful indeed :)
Thanks indeed guys 8)
I made a quarterwave antenna out of an old aluminium shower rail and it works quit well but u can buy a tankwhip for £15 or a halfwave GP antenna for £25 quid .it will be difficult to make a 18 ft halfwave vertical antenna out of junk, U could try 2 9ft fishing rods to make your wire dipole vertical but how much would 2 fishing rods cost and a proper dipole is only around £18 new .
rogerroger
hola my friend I made with two pieces of aluminum pipe 2.50 m of 5/8 inches! Which perfectly fits inside a pipe 1/2 inch mold.
with a T 1/2 inch make the support.
So a good vertical antenna in L with good results and good bandwidth.
If you need photos I'm available.
yes please. put some photos on the forum *King*
