Hi everyone,
I've recently bought a Eurosonic ES200 and used it for the first time in anger last weekend for 4x4 convoy driving. I've decided I need a mic so I dont have to pick the whole thing up when driving, and an external aerial as the rubber duck has very little range inside the car.
However, all the mount kits for aerials come with a much larger (screw-on) plug fitting than the 9mm or so bayonet fixing on the radio. Is there some sort of adaptor for this? Also, would the aerial still have to be SWR tuned if its being used with a handheld?
Ditto the mic fixings - they all seem to be large screw-in connectors, are there any with a miniature (2.5mm?) headphone-style jack?
Thanks,
Matt
ES200 Mic and antenna connections
- andy@thunderpole.co.uk
- Site Admin
- Contact:
Hi Matt,
You will need an adaptor to be able to plug in an external antenna, however unfortunately that radio is quite an old one so I don't think we stock them anymore.
The microphone you would need is a speaker mic on this page... http://www.thunderpole.co.uk/speaker-microphones.html
From memory the ES200 is Standard wired, but it has been a few years since I last saw one!
Hi andy, thanks for the help. Do you know what the name of the fittings on the adaptor would have to be so I can try ebaying for one? (ie. x-to-y adaptor?)
The microphone socket is a 2,5mm jack, sited next to a 3.5mm jack for a speaker. Having googled the standard wiring you mention, it looks about right. However, I did want to have a separate (large) speaker as I have a very loud and drafty old land rover - how powerful are the top spec speaker mics you sell?
Thanks,
matt
Thanks,
matt
Uh, Breaker One-Nine, this here's the Rubber Duck
You got a copy on me Pig-Pen? C'mon
Yeah, we definitely got us the front door good buddy,
Mercy sakes alive, looks like we got us a CONVOY
I believe you will find that you need a BNC to SO239 adaptor for attaching an external antenna.
Something with a cable like this: eBay Linky
or a simple plug adaptor like this: http://www.thunderpole.co.uk/adaptors/b ... aptor.html
The top of your radio looks like this, right?
- Site Admin
- Contact:
Sorry Matt, Guzzy is totally right, a BNC to SO239 adaptor will do the job.
It was friday afternoon when I answered you so I must have been on the wind down to the weekend!
We do plenty of extension speakers here... http://www.thunderpole.co.uk/extension-speakers.html
The most powerful is 20 watts, but that handheld won't be able to run it at its maximum so any of the speakers, even the small 5 watt ones should give you an advantage over the inbuilt speaker.
Thanks very much Andy and Guzzy!
My radio does indeed look like that, I think I will buy one of those adaptors so I can they buy one of the normal ariel+mount kits thunderpole sell as well (once I've decided between gutter and mirror arm mount!).
I get what you mean about driving a larger speaker, in that case if the speaker mics are 5 watts or so I might as well just get a standard wired one of those rather than faff about installing an extra speaker too.
Regards,
Matt
Regards,
Matt
