What is the purpose of an amplifier???
Get a better aerial before thinking about an amplifier.
The aerial and a good installation makes all the difference.
Your radio puts out 4W (the legal maximum), this is good for about 5-10 miles (depending on terrain) on a mobile setup. The amplifier takes the 4W and (illegally) 'amplifies' it to about 25W. This has the effect of increasing your range by a small margin (5-20 miles?). Nothing is certain and intervening terrain will still block your communications.
So let me get this right, by adding an amplifier I can increase the range of transmissions to 20miles???? When you say it is illegal, how would you ever get found out??? Do the plod have equipment to check output of a CB signal?
I am only going to fit an Orbiter HD aerial as it will be part of my 4x4 set-up and rig. (Thunderpole T1000).
It might do, it all depends on what is in-between you and the other person you are trying to talk to. If you are in a dip, your range might be 2 miles, if you drive to the top of the highest local hill, your range might be 30 miles, 40 miles, maybe 50 miles.So let me get this right, by adding an amplifier I can increase the range of transmissions to 20miles????
But a person in a dip 3 miles away might not hear you, or you might not hear him trying to get back to you. He's blocked by the dip he's in. It's just the nature of direct radio communication. The other issue is that you might reach 25+ miles, but can the person at the other end reach back to you on 4W? Probably not.
It's very unlikely you would be 'found out'. But it's not impossible, so you can't say you haven't been warned in advance.When you say it is illegal, how would you ever get found out??? Do the plod have equipment to check output of a CB signal?
