Ok got my swr meter today set it up and tried to tune my ariel it came with my cb .
I know it says pretuned but i was told to test it anyway and im glad i did im getting readings of 5 in the red on 1 and 40 and no matter how i tweek it it stays the same ,i have it roof mounted on my Pajero and am at my wits end .. i would like a larger ariel for better distance and want to mount it on my bullbar ...any ideas or tips for which to get would be great and any help with my present dilemma would be fantastic
Cheers guys
aaarghhh
show us pictures of your set up , Sounds like a dead short or antenna is duff . A ohms meter (digital multitester) is your best tool for for fault finding .
http://www.thunderpole.co.uk/test-equipment.html
if you look at the meter carefully you will see a difference between the readings it should be higher on 40 than one if so cut the whip by about 1/4 of an inch and check again dont mount on bull bars as the rule is the higher the better
