How to ground Antenna?
AppleTree
CB Handle: Uncle Bulgaria
Hi, I have a problem that my two CB Radio's won't transmit although they say they are (TX)
I have a magmount 1000W 6ft antenna, that I have put in my loft.
I understand they earth through the magnet,(Although i don't see how because it has rubber on the bottom? so I have stuck it to a bit of metal, and I have 2 earth cables running from that to water pipes. one 6mm Cable and one 10mm cable. I have two because I tried with one and it wouldn't work so I tried having two. Still no luck.
The radio's worked fine when I bought them so the seller said, My antenna is new and meant to be pre-tuned, the SWR is 1.2.
If I have the Squelch to min, and go and touch the antenna, the noise stops, and if I let go it comes back, is this normal?
Can any of you think of what my problem could be?
Or 145.500 FM 8-)
Hi RustySkull,
What radios have you got? Are they new?
Have you checked what band they are set to? Most modern CB radios have multi-band capability, so you need to make sure they are both set to the UK band.
1.2 SWR reading shows that your antenna and cabling are working fine, so it is definitely down to one or both of the CB's.
AppleTree
Hey!
No they aren't new, I can give exact info later on, but I know one is a Murphy and looks quite old. It had a power meter on it with a dial, the other is newer. They were both serviced before I bought them.
Have I earthed my antenna correctly?
Or 145.500 FM 8-)
sounds like you need an SWR meter to check the antenna do not take anyother persons word for the swr cause all ground planes vary the reading and the antenna that say pre-tuned are done on a perfect set up so disbeleve them
my tyres say india on them but they have never been there so do your own checking for the swr to start
AppleTree
Hey, I have ordered a SWR mater, but for that reading I borrowed one from a guy at work lol
Or 145.500 FM 8-)
Well if you are getting a SWR reading of 1.2 from the antenna now, I would say that there must be a satisfactory ground plane.
The problem must lie with one or both of the radios. Is the Murphy definitely a UK FM radio? Do they both have UK stamps on them? i.e. UK 27/81?
Andy.
AppleTree
Murphy
Model no. DS 602
40 channel FM mobile
Citizens band transceiver.
Other is a
Kernow CB Transceiver
Model Beta 1100 UK
27 MHZ
Or 145.500 FM 8-)
AppleTree
Okay, so I got my SWR Meter in the post this morning, this time it's reading well over 3!
I think it's my ground plane, can you please give me tips on how to ground a magmount whip antenna? There is no grounding points on it! :(
Or 145.500 FM 8-)
AppleTree
Or 145.500 FM 8-)
Andy Nazel
Hello Rustyskull :D .First may I warn you against connecting the aerial to the magmount with bits of wire as this sends all the radio's transmitting power straight back into the radio and will damage it!The aerial itself is commonly referred to as a "springer" and are notoriously difficult to swr.Sometimes you can put one on a car and it will SWR perfectly but mostly they are well out.Another point is when SWR'ing an aerial you need to use CH1 and CH40 that way you are checking the SWR at both ends of the radio's transmit range(remember to "SET" the SWR meter for both channels to get a proper reading and use the radio's full power).Having looked at your video I would go back to using the metal disc and put your grounding wires on that.If the SWR is higher on CH40 and lower on CH1 the aerial may need a little cutting off the top but let us know your SWR on 1 and 40 and we'll go from there.By the way "springers" are a little bit "deaf" in my experiance.The homebase aerial you asked about will do a much better job as a big outdoor aerial always will compared to a mobile aerial indoors,you'll also need wall brackets and a pole strong enough to clamp the aerial to.
AppleTree
Hi, thanks for your reply :)
I have since given up in the loft, and moved it downstairs, and stuck it to my Radiator, the Antenna is on the floor but the SWR is about 1.4, and last night I managed to talk to someone in Basildon (10 miles away) He said I gave him a reading of 9, what ever that means lol. Anyway.
Anyway, last night I ordered a base antenna and 20 meters of Coax cable and 2 PL259's.
From the Thunderpole shop.
Can you give me an idea as to how long these will take to arrive? :)
Or 145.500 FM 8-)
well your getting there it should arrive tuesday with the service that thunderpole gives enjoy
AppleTree
stampman wrote:well your getting there it should arrive tuesday with the service that thunderpole gives enjoy
Ahaaa sweet! :)
Or 145.500 FM 8-)
I think Chicken wire laid out on the loft floor to the size of a car used to be about the best ground plane to stick a magmount on .
AppleTree
Lol I stuck it to my radiator down stairs now :)
Getting range of 20 miles :)
Or 145.500 FM 8-)
