High SWR
lone-ranger
Hi there I recently got a new van a 09 ford transit low roof. I fitted a sirio body mount in the middle of the roof with sirio performer 600 antenna it's a brand new mount and coax. on a midland Alan 48 radio I also run a separate cable from the underside of the mount bolted to the bulk head in the van as an extra earth for the antenna. I had the same set up in mynold van pergeot partner with swr of 1.2 on both channels. But on the new van I can't seem to get my swr below 2 on channel 1 and 40 and is around 1.8 and I feel this is affecting the performance of the signal I seem to be able to pick up strong signals glomming in but lots of interference. I have spoke to a few people who say I have sounded crystal coming through but I think this was only at a distance of about a mile at a push. Any ideas of how I can get the swr lower? Or am I worrying about nothing? Hope you can help. Many thanks Ryan
26-TM-037
The Sirio performer 600 is only 1250 mm, shorter antennas are notorious for try to achieve a low SWR. Try a bigger antenna Ryan, antenna size is everything in this game of radio. I use the Sirio 5000 and found I needed to cut off a couple of inches to achieve a low swr.
take the extra lead off if its a metal roof it don't need it and you could be getting reflection from the van roof
lone-ranger
Hi Guys thank you very much for your replys. I would prefer to use a smaller antenna as I live in London there are lots of low bridges I will hit which is why I went for the performer. I took my swr reading in the countryside in an open space. This morning I took that extra lead of as you said and I got the swr at 1.8 across channels 1/19/40 I think maybe that is the best I'm gonna get as I also tryed my orbiter and trucker 80 antennas and I'm getting the high reading on them too. Must be something on the van? I looked on this forum and found another guy with the same problem as me on the transit. And someone recommended a omega 27 antenna to get the low swr and performance?. Do you no much about these antennas I was thinking to buy one and try it out. Thanks again for your help :) also just want to add when I got my copy with another breaker about a mile away I was in a built up area. Today I got a radio check on a big hill and got someone at 5 mile who got me coming through clear. He was burning 10 watt but he was crystal clear on my rig. So I'm starting to think maybe I'm being to fussy.
twas me who recomended the omega 27 i fit a heck of a lot on waggons and the swr will come down for fun you need to cut it use ch1 on mid band and ch 40 o0n uk and it will work fine i get a check on each one i fit and he is 4 miles away as the crow flies and always a good signal going out
lone-ranger
Thanks for your help stampman I ordered a omega 27 from thunderpole last night. Hopefully I will get that low SWR I'm after. Thanks for your help ill let you no how I get on once I have a chance to get it up and tuned. :)
lone-ranger wrote:Thanks for your help stampman I ordered a omega 27 from thunderpole last night. Hopefully I will get that low SWR I'm after. Thanks for your help ill let you no how I get on once I have a chance to get it up and tuned. :)
good luck with the new antenna :D
lone-ranger
Hi guys put up my new omega 27 today. I'm getting great low swr on it! But the only problem is I'm not even getting a reading on uk channel 1 on the mid band channel 1 I'm getting 1.2 and uk40 I'm getting 1.2 channel 19uk I'm getting 1.1 is this ok? Or do I need to tamper with it more? I'm just not sure as I cant get a reading on uk channel 1. But I'm very pleased with the antenna it's looks really smart :D
no thats fine use and enjoy
lone-ranger
Thanks for all your help and great recommendation!
Will be looking forward to getting out on the road and hopefully get talking to some friendly breakers! :)
i would have gone for the super nova but that would have been my choice if i was going to go for a small antenna as it has a centre loaded coil & will give a better performance than base antennas but hope the omega 27 does alright for you buddy :D
lone-ranger
Hi wildfire thanks for your input. I do have a supernova knocking about somewhere but I don't no what iv done with it. I have so many antennas I have bought over the past 5 years. I have a trucker 80, a orbiter, sirio performer 600, supernova, 3ft firestik, 4ft Firestick and now the omega 27 which seems to be working well on my van. I'm thinking to try a sirio mythos 9000 a go as well to add to my collection. it looks like a bigger version in the omega! Think I have way to many antennas!! But what the hell I'm sure I'm not the only cb nut with 20 antennas haha :)
best mobile antennas are the centre top loaded antennas as it all comes down to the coil top loded antennas work better than centre loaded & the center loaded works better than base loaded antennas at least you have the firesticks what are the best in your collection same as the DV27s been top loded but no good for vans as you may know they are thicker but if i was going to run around with a firestick i would attach the 3/8 antenna spring http://www.thunderpole.co.uk/mounting-a ... pring.html also the orbitor is pre tuned & don`t need cutting or trimming & the SWR will be about 1.1 or should be & will handle low bridges & trees what need cutting lol well mine does & i go around in a iveco daily van m8
lone-ranger
I totally agree with you I have the spring for my firesticks but I think it looks a bit of an eye saw on my van they look great on big American trucks though. I would love to use my orbiter but for some reason I just can't get a low swr on my transit! I think it's getting reflection from the roof. On my old van I had a pergeot partner I had no issues with swr at all so I'm a bit limited to wat I can use. The omega 27 has been the only antenna I can get my swr down to 1.2. So I'm having to comprise. I'm thinking to stick a small 80w amp on there to help me get out a bit better as I'm finding that I'm getting crystal incoming signals but can't seem to get heard unless I'm at quite close range. Wat do u think? Or am I better just to stick the orbiter up with high 1.9 swr? It's so hard to get it right to the point that I'm happy with my set up. I maybe to fussy haha :)
i have read by some users who also use the tri-star http://www.thunderpole.co.uk/mounting-a ... -star.html as they say it helps to lower the SWR a bit also some antennas are a pain to get the SWR low but lets see if we can get your SWR low for you buddy so you can use your orbitor you will defiantly be heard first thing i would like to ask is what mount are you using ryan if you don`t mind me asking m8 is it a mount so you had to drill a hole in the roof of your van :shock: i would also remove the separate cable from the underside as this could interfere with getting your SWR lower a better mount would have been a 6" or a 7" mag mount or a gutter mount if your van has a gutter i know not old motors have these days but fingers crossed lets hope yours has also another idea would be a hatchback mount only if your rear door open upwards.
