burners advice needed
welshbaycouple
Hello everyone i have a 40w burner......it says input fm 1-5w input ssb 10w my rig puts out 10w on fm and 21 on ssb...will i damage the rig or amp if i use it on my cb radio?
just watch the smoke from the burner rise up not a good idea it only does what it says on the tin
CrunchyNut
I've thought about using a burner but then read somewhere that if you get caught out the fine is £1000 plus a criminal record :(
yes it can be expensive
:D :D :D :D :D
