High SWR
lone-ranger
Yes it's a fixed mount I drilled a hole in the van. I did remove that extra earth cable. I do have a mag mount which I tried but seemed to still get the high swr although it was a bit better. I do have a gutter on my van so that could be an option. But I do prefer the fixed body mounts as I like to keep all the cables neatly hidden as opposed to coming in through the doors. At the moment I got a DV mount on there but I also have a 3/8 and the sirio SOthingimijiggi mount. I really don't no wat is causing the high SWR on most antennas I have the. omega SWR I got on there is spot on but obviously it is only a small antenna so works well but only at a small range. :)
yeah there`s a thought what i would try is the 3/8 body fixed mount if the SWR is still high then there is a problem with your mounts not getting enough earth but if that don`t work you could try a gutter mount & lead your coax through the top of your rear door but will think of more options while i am asleep for you m8
Asterix
Hi lone-ranger
I often use a sirio mythos 9000 and found it to be a very good antenna with very low s.w.r. across all channels sometimes not moving the swr meter needle at all on some channels. It seems to get out quite well too!
lone-ranger
That's great I'm going to try one on sat. I see your location is sanderstead I myself live in Balham but my grandad lives in sanderstead/south Croydon just of Carlton road and I'm going to visit my parents in Caterham on the hill on sat so maybe ill give u a call out on the raidio on sat for a good test up :)
I have tried the mythos, and to be honest not as good as they make out..
if you want a good mobile aerial, go for the hi-power or megawatt 4000 (both the same by sirio)
a bit big at nearly 7' or the sirio ML-145 a smaller version as i got a good range of 26 miles with a ML - 145
both are based on the old avanti (other company) range and work suprisingly well..
all depends on your useage, but a simple orbitor will work well and with a good SWR.
& when the budget is right for you buddy & you like your cable nice & tidy maybe a side mount,
http://www.thunderpole.co.uk/fixed-body ... t-kit.html just another option for you buddy.
Asterix
As wildfire says, the Orbitor works well, I would go for the larger type though as I have had swr problems with the mini ones (being springy they can withstand a bash or two from a low bridge etc :) ) Yes, Give me a call saturday if your passing through.
