KIT: 1 x Cody Box Kite, 1 x Baofeng UV5r, 1 x Radio-Tone Simplex repeater, one camera pouch, one small carabiner, 200m 60kg breaking strain kite line.
METHOD: Set it all up in the ground, place radio and repeater in camera pouch, turn them on, check all connections, clip carabiner thru the bridle of the kite. Launch. Using a second radio, I use a Baofeng 3r on low power with short stubby (50cm) antenna on e ground to communicate via the Sky Repeater aloft. I maintained a contact 10miles away for 1.5hrs, signal 7-9. Anoth station in the opposite direction approx same distance reported strong 30+ signal. All on handies!! With rubber duck antennas. The kite sits at around 45m high, give or take drops in wind speed. I shall be going up to 60m (legal max) weather permitting.
This is just pure fun, an experiment to see what it can do, I'm no radio ham, or radio expert, I just like trying out ideas. I've also made a 11m wire dipole to lift with the kite, getting the most bangs for my bucks, and I get to play with kites.
I've now made up a wire dipole for the kte, that fits to the kite struts, early ground level tests (no wind right now) giving good signal output, may the fun commence
