I've recently fitted my rig in to a new lorry. The squelch seems ridiculously high. By this I mean that I have to have the squelch knob turned right against the stop before I can get rid of the hiss.
What is causing this as i'm squelching out the people need to speak to.
Squelch Question
In my truck i get quite a bit of interference when the lights are on and the fridge is running but the interference moves channells each time i change trailors so some trailors its ok on 19 , other trailors 19 is a wright off .During daylight hours the radio is usually not bad with the odd trailor giving a bit of ABS noise on the CB when i brake .
