What's a better burner ??
Baxtoot
Hi all
Was thinking of getting a rm kl 200 or a zetagi b153 burner both 100w am/fm and both 200w ssb but unsure which one to get the zetagi is around £5 cheaper !
Which is the better model and which one is more durable ??
Thanks in advance
zetagi are very good burners :) not had any problems with them
Mudslinger
I have an RM-KL-203p and it has been excellent.
Puts out a true 100w with about 8w in, and the pre-amp is very useful on occasion.
Baxtoot
Mudslinger wrote:I have an RM-KL-203p and it has been excellent.
Hi
Thanks for replys guys !! Where could I get one of these from in uk. ?
Mudslinger
I got mine from Knight's although I have also seen them on ebay.
I also forgot to mention that unlike many cheaper amps it also sounds very good on SSB.
Baxtoot
Mudslinger wrote:I got mine from Knight's although I have also seen them on ebay.
I've just found it on (other company) cb for around £55 in blue is it 100w fm / 200w ssb ? Couldn't find the specs for it ?
Cheers mate
Mudslinger
That is a fair price, and yes it is specced at 100w AM/FM and 200W SSB.
You can get 100W on FM but you will struggle to get 200w SSB, 160W being more realistic.
The input is 10W AM/FM and 20W SSB although you will be better off running slightly lower.
Mine draws about 18A flat out on SSB
The main specs are the same as for the non preamp version.
Baxtoot
Thanks for your replys mate very helpful
Would a 10/12amp power supply be ok to run the burner ?
Sorry for the questions bit of a newbie
Mudslinger
You will need a bigger PSU that that.
The one I have is a 25A and it just about managed to power the burner and my President Grant.
My PSU is a MAAS switchmode type and cost about £55 from ebay.
Baxtoot
Mudslinger wrote:You will need a bigger PSU that that.
Hi
It's only to power the burner the 10/12 amp I have a separate psu for my rig
Sorry for the confusion the specs say input power min 10amps so should be ok ?
Will be running to 2 psu 1 for rig 1 for burner
Thanks for advice
Mudslinger
The Burner draws about 15A on its own, I know this as my PSU has a built in Ammeter
The spec says 10A but it is wrong.
It is also a good idea to have some spare capacity in your PSU. Running them flat out isn't good for them in the long term.
